--> OTK Axles – ekartingnews
Home Forums Chassis & Handling OTK Axles
This topic contains 6 replies, has 5 voices, and was last updated by  TJ Koyen 4 years, 3 months ago.
  • #18290
    Michael Rutter
    Hello, I recently purchased a 2014 Tony Kart and have been wondering what axles people use commonly.  Which axles are the most useful to have? In the rain should i be looking for the E axle? or the U?
    I managed to find this chart
    from softest to hardest… E-U-Q-P-N-H-HH
    So which axles would you recommend for a kart running a leopard?
    Also the MXC and MXP wheels… Would you recommend spending the $800 for the MXC’s?
  • #18293
    Tim Koyen
    Rain axle…Q or U.
    MXC wheels…without a doubt.
    KartLift Kart Stands
    DeepSeat Kart Seats
    877-777-8020
  • #18298
    N axle works in the dry about 95% of the time.
    MXP if you’re racing in really cold, low grip situations, MXC for anything 50*F and warmer. So basically 95% of the time.
  • #18350
    What ‘s the advantage to a set of $800 wheels Vrs $200 for a set of DWT’s  ??
  • #18357
    MXC wheels are the best for keeping the tire consistent throughout a run. We’ve back-to-backed a few different wheels including the DWT LV and SE against the MXCs and found the MXCs to be the best for keeping the kart consistent over a run and keep the tires in their prime operating window.
  • #18381
    Jeff Shadoan
    TJ
    In your testing, how did the DWT SE wheels compare to the MXPs vs MXCs?
    Also, do they have the same offset as the OTK wheels? If not, how much do they differ?
  • #18393
    <div class=”d4p-bbt-quote-title”>TJ Koyen wrote:</div>
    TJ
    Jeff,
    It was a while ago but if I remember correctly the SE wheels felt similar to the MXCs, but the MXCs still held up better over a long run. Overall they just felt more consistent and predictable than the SEs. Both wheels felt like they took grip out of the tires and helped them run cooler.
    Can’t remember the offsets off-hand.
