Home Forums General Karting Discussion Open Trailer for Kart
This topic contains 2 replies, has 2 voices, and was last updated by  John Barthelmass 10 months, 4 weeks ago.
  • #79977
    William Weiler
    I found this aluminum 5’x8′ trailer for a Kart. Do people typically use 3/4″ plywood deck? Maybe I could save weight with thinner plywood. How do people secure the Kart to the trailer? Are there special tie-downs for it?
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
    #79978
    William Weiler
    As a follow on question, how do people keep road grime off the Kart? Seems like a normal Kart cover may come off or rip in the wind.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
    #79981
    John Barthelmass
    I’ve towed using one of the 4×8 foot Harbor Freight open trailers for years, and think I’ve arrived at a pretty good scheme that is as light as possible. I carry two karts that I load across the trailer (one facing toward the passenger side and the other facing toward the driver side) one behind the other. The trailer has two 4″x4″x 8ft boards attached lengthwise (spaced apart similar to the way a kart sits on a stand), and the karts rest on their frame rails on top of these carpet-covered beams. I’ve installed eye bolts on the trailer rails located to allow for tie-downs to each kart axle (2 per kart) and tie-down to the frame rails near the front wheels (also 2 per kart). Tie-downs can be whatever you’re comfortable with and confident that they won’t loosen in transit.
    I’ve used this setup for six years now, and I’ve never had any issues. The tow vehicle punches a big enough hole in the air to protect the karts, so road grime hasn’t been a problem.
    I recently used this rig to tow 2000 miles cross-country in preparation for moving back east, and it worked fine the whole way.
