Home Forums Road Racing New England Road Racing! (KartMania July 8-9 2017)
This topic contains 3 replies, has 2 voices, and was last updated by  Ian Krueger 7 months, 3 weeks ago.
  • #81643
    Ian Krueger
    pre registration is now available at NHKA.net
    We hope to see you there!
    WKA sprint
    #82514
    Keith Buffo
    If you can’t wait for Kart Mania! you don’t have to… the NHKA Racing Series will be on the full road course at Canaan on June 17th. Check out http://www.NHKA.net for details.
    #82851
    Ian Krueger
    After a successful event yesterday at Canaan Motor Club’s full road course, i (attempted) to shoot a video of most of the race before retiring with 10 minutes to go. We should have had 10 second green flags instead of all going at once because the TAG group screwed up the start for my class. Anyways here’s the video
    bring your big rear gears and 14 tooth drivers beecause its around a 6.0-6.4 gear ratio for laydowns/sprint 2 cycles
    hope to see you there! pre register at NHKA.net
    WKA sprint
    #83027
    Ian Krueger
    One thing I should add for enduro/axle clutch guys, make sure you bring some chain gears and driver’s and also Sprint springs for the clutch because if it rains we will run the shorter course and that is about a 7.4 ratio and you won’t be able to achieve that with belt gears and enduro springs. Also bring 12 tungsten’s! Hopefully the weather is better this year, short course if it’s down pouring. The track is really slick in the rain and there’s some off camber corners here and there so just a heads up to consider
    WKA sprint
