Home Forums Shifter Karts New age body work questions
This topic contains 1 reply, has 2 voices, and was last updated by  Spencer Uzri 5 months, 1 week ago.
  • #85748
    Blake Foley
    hello,
    i have a 2008 crg road rebel and I would like to put the new age body work on and I was wondering if this is a direct swap to my 2008 chassis. Or if all crg chases use the same mounting for body work.
    thanks for your time !
    #85782
    Spencer Uzri
    If I understand your question, the chassis bodywork mounting points are standardized according to spec, which the ’08 RR conforms with.  Each bodywork style has a particular brackets/bars, but they all conform to this std where the bars interface/insert with mount tubes on the chassis.
    The thing that might take some mount “customizing” would be the front “nassau” steering axle panel.  For example, when I changed mine from NE 2 to Evo, I had to add a ~2″ spacer nut to the bolt to raise the Evo design (It’s a bit more low slung compared to the NA 2 style) so it could clear the steering wheel.  You’ll have to install it to check for clearance issues.
