Home Forums General Karting Discussion New 180mm x 16mm Tony Kart rotor
This topic contains 0 replies, has 1 voice, and was last updated by  Vic Eacott 3 years, 12 months ago.
Viewing 1 post (of 1 total)
  • #20313
    Vic Eacott
    Hi guys
    I’d said I would mention to you all, using Tony Kart chassis, when the new 180mm Tony Kart rotor was produced………….well, it’s out now and available through the dealers http://www.frixa.org/dealer-network There also, is a photograph http://www.frixa.org/news of the comparable aero dynamic shot of the vent that we have created to assist you guys in hot weather racing. GUARANTEED not to over-heat your bearings, axle, hubs and not to increase the left hand tire pressure from heat dissipation as the original Tony Kart rotor does.
    This rotor is 16mm wide compared to the OTK rotor measurements of 11 / 12mm and, our rotor is created from one piece of cast iron (CNC production) NOT from a casting that has uneven mould ‘flaws’………….Each rotor’s completed vane production takes 3 hours so you know, each and every cooling vane is precise to the circumference of the rotor.
