Home Forums 2-Cycle Racing Need help with MIni Swift 60cc (IAME)
This topic contains 3 replies, has 3 voices, and was last updated by  Scott L 2 years, 6 months ago.
  • #53696
    Scott L
    New to this forum, karting and the Parilla IAME Mini Swift…   Just purchased a used 2015 Top Kart Blue Eagle with a 60cc IAME Mini Swift.   The kart and motor has only 1 hour on it.  We are having problems with the motor starting and maintaining a steady idle once we do get it running. Is it normal to crank the motor over and over? I do seal the intake port with my hand on the air box until is gets going. Frustrating..  Also, it seems to idle high as well once we get it running.    It will run fine on the track but once my daughter comes into the pits the motor wants to stall.    We are using the NGK plug that came with it and always fresh gas (Sunoco 93) Is there some advise…    Thank you!
    lynn haddock
    Eric Stevens
    When cold you will need to choke it by covering the airbox tube to richen the mixture. Also the added vacuum helps get the diaphragm in the carb pumping fuel as well. Dont give it any throttle until after it fires, this can take more than a few seconds when you first get to the track, after it has been running it should fire right up but still dont give any throttle until after it fires.
    You might need to adjust the carb,  A good starting point would be 1-1/4 to 1-1/2 turns open on the low needle and 1/2 to 3/4 on the high.
    Also the carb should be cleaned regularly, dissemble the carb completely and clean the carb and all passages with carb cleaner, just carefully wipe clean the rubber parts, inlet needle and pump diaphragm. Clean the inlet screen and reassemble. There are some videos you can watch to learn how to do this.
    Idle once warm should be high probably over 3000 rpm if it will idle.
    You need to clean the plug if its a new driver and they aren’t driving hard at full throttle for most of the lap. An abrasive plug cleaner is recommended from aircraft spruce or harbor freight tools. Use a BR9EG when its not being driven full tilt and especially when outside temps fall below 75 degrees. A BR10EG is recommended for 75 and above when you are driving it hard.
    It is normal for it to want to stall when coming off the track.
    Scott L
    Thanks so much Eric! Great information!!   We will try all that you recommended this weekend…  Scott
