--> Need help with kart ID – ekartingnews
Home Forums General Karting Discussion Need help with kart ID
This topic contains 12 replies, has 7 voices, and was last updated by  Gary Osterholt 1 year, 6 months ago.
  • #73207
    Steve Eamiello
    Hey guys
    Just picked up a kart and need some help.. the ID tag behind the seat is gone. From what I’ve gathered it’s one of Tony Kart’s offshoot brands- I just can’t pinpoint which one, so any help would be greatly appreciated. The frame is blue with gold tie rods and OTK master cylinder. Front & rear brakes with TK marked discs. TK pedals and steering wheel. Fireball 125..
  • #73209
    Matt Martin
    are the blue ones FA kart?
    • #73213
      Steve Eamiello
      From what I’ve seen, yes.. but not exactly sure..
    • #73218
      Aaron Hachmeister
      It depends, theres two blue OTK chassis, the darker blue/purple of the Kosmic and the lighter blue of the FA. This chassis is an FA from the powdercoat, but the lack of other OTK components is a little strange… The tie rods are OTK, but I’d have expected it to carry OTK bodywork, and the seat. Definitetly interesting to see, granted I’m not the expert of karts by any means. What do you plan on doing with it?
      • #73233
        Steve Eamiello
        Aaron- I’m actually trying to trade it for a Banshee.. or ATC250R / Fourtrax.. We’ll see how it goes!
  • #73212
    Steve Eamiello
  • #73219
    FREDDY SANDOVAL
    Steve. This is an early Tony Kart model ( pre 08 or 09) Maybe even older, as the side pod nerf bars go towards the front rather than on the side, it also has a welded tab at the end of the inside  frame rail at the back.
    Overall I think it may be a 2002 to 2008 Tony Kart Mitox, and somebody powder coated it blue, as there were no Alonso karts or Kosmic Karts back then.
    Anyhow, I hope this helps, and good luck with your plans. FastFreddy.  .)
  • #73228
    Nik Goodfellow
    Its a Tonykart Mitox 2000-2002, powder coated blue. You can tell it is pre-2003 due to the old style sidepod mounting bars configuration (angled rather then straight).
    Back then FA kart didn’t exist but Kosmic has been around since the 90s’.
    Looks to be mainly authentic components, with extended front for tall drivers. Back then tonykart ran tillet seats.
    • #73232
      Steve Eamiello
      2000-02? The markings on the Fireball motor are US 2118
      11.06- so the motor is an 06? I’m obviously not sure of the motor numbers either.. thank you both for your help.. so you both agree on year /model?
  • #73266
    Nik Goodfellow
    Engines and karts are interchangeable. You could theoretically put a 2016 motor on a 2001.
    Sorry I don’t know much about the PRD fireball, but I had a Mitox in 2001 and 2002.
  • #73279
    Steve Eamiello
    Ok.. now that we’ve solved that riddle- anyone know what it’s worth? I know the Fireball motor goes for around $1500..
    Anyone? Bueller??
  • #73280
    Dan Brown
    Brand new Fireball engine packages are around $1500, they are a very reasonably priced TaG package. Used ones on here typically bring around $500-$600.
  • #73282
    Gary Osterholt
    Complete package at most would be around $750- $1000 due to the age of both.
    Gary Osterholt
    GO Designs, LLC
    http://www.godesigns.us
