--> MyChron5 sensors – ekartingnews
Home Forums General Karting Discussion MyChron5 sensors
This topic contains 4 replies, has 4 voices, and was last updated by  Craig Drabik 1 year ago.
  • #79883
    William Weiler
    What sensors do people use for Lo206 racing? Also, how does the unit measure lap times? Is it GPS? I don’t see how that could be very accurate.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
  • #79887
    Not sure on the specifics for LO206, but you’ll want RPM read-out and lap times at least and probably an engine temperature of some kind.
    The MyChron 4 and older gauges use a timing beacon that trips every time you pass to measure lap time. MyChron 4 can also use GPS. MyChron 5 uses only GPS and it’s fairly accurate.
  • #79899
    Craig Drabik
    I’ve run cylinder head temperature on World Formula engines in the past, but I don’t think it’s necessary.  For LO206 probably even less necessary.  You don’t have to worry about head temps like on a Yamaha.  Just RPM and the correct lap beacon for the track.
  • #79900
    IMO – The most accurate sensor for recording lap times is your transponder.  You should be able to fit a magnetic or RF sensor to the M5 for lap times.  But the all the AiM lap time sensors have their faults. Use the GPS on the M5 and don’t be concerned about the other lap sensors.  I was a GPS skeptic, not any more.
  • #79918
    Craig Drabik
    Good point – I’m using GPS on Mychron 5 as well.
