--> MyChron & Unipro Data Systems & Parts – ekartingnews
Home Forums Classifieds Classifieds – Parts MyChron & Unipro Data Systems & Parts
This topic contains 0 replies, has 1 voice, and was last updated by  Eric Nelson 1 year, 10 months ago.
  • #67071
    Eric Nelson
    Please contact Eric at 626.232.9477 or e-mail:  eric@seventh-gear.com .  Buyer pays shipping, I am Paypal Verified.
    AIM MyChron 3 Gold w/ eBox & Steering Wheel – $350
    –  MyChron 3 Gold display w/ eBox, tested w/ good batteries
    –  New 14mm cylinder head temperature sensor w/ cable
    –  10mm Water temperature sensor w/ cable
    –  RPM cable
    –  IR timing receiver pickup
    –  Wheel speed sensor
    –  50mm axle collar w/ wheel speed magnet
    –  USB download cable
    –  MyChron 3 steering wheel, rated in “Good” condition
    AIM MyChron 4 w/ eBox Extreme and steering wheel – $750
    Early-type GPS will require configuration (software is not included).
    –  MyChron 4 dash, shows normal light spot fogging of display cover that does not affect function (see photo)
    –  MyChron 4 eBox Extreme, with inputs for:  Lap Time, (2) Temps, Speed, and (3) Open channels (can be used for Speed, Throttle, Brake or Steering sensors)
    –  eBox mounting bracket
    –  Early-type GPS module (software not included)
    –  4-Position data hub
    –  10mm Water temperature sensor w/ extension cable
    –  Exhaust Gas Temperature sensor w/ extension cable
    –  RPM cable
    –  IR timing receiver pickup / long cable
    –  New front wheel speed sensor w/ long cable
    –  (3) Threaded wheel speed magnets
    –  New rear wheel speed sensor w/ extension cable & mounting bracket
    –  MyChron 4 steering wheel,shows some arching, rated overall in “Good” condition.  Gauge mounting bracket screws are not included (see photo).
    Unipro 5004 Complete system w/ factory Energy Corse display – $850
    Used one time, in as-new condition.
    • Blue anodized factory Energy Corse 5004 display with laser etched logo on top
    • 5004 main box w/ good batteries installed
    • RPM sensor
    • IR lap time receiver with mounting clamp
    • Water temp sensor kit w/ hose fitting
    • Wheel speed sensor w/ mounting bracket
    • Front & 50mm rear wheel speed multi-magnet collars
    • Brand new infrared transmitter beacon
    • 5004 Software CD-ROM
    Unipro 6003 Big Kit complete system w/ blemished display – $700
    Good working condition, display cover shows cosmetic laminate damage from tape being applied.
    • 6003 display w/ cosmetic blemishing (see photo)
    • 6003 main box w/ new batteries installed, missing one cover screw
    • RPM cable w/ minor blemishing (good working condition)
    • New water temp sensor kit
    • New exhaust gast temp sensor kit
    • New wheel speed sensor
    • 6003 Software CD-ROM
    Unipro 6003 Mainbox + Sensors – $375
    Tested in good working condition w/ new batteries.
    • 6003 main box w/ new batteries installed, missing (2) cover screws, edging on Recv 1 jack is slightly bent from storage but in good usable condition.
    • RPM cable w/ sheath repair
    • New IR lap time receiver
    • Water temp cable w/ sheath repair
    • Wheel speed sensor needs sheath repair
    Unipro 4503 complete system new in box – $200
    Unipro Accessories:
    Infrared Transmitter Beacon #10-03-003 new – $120
    Unipro G-Force Sensor #10-13-001 new – $300
    Unipro External Box #11-04-002 new – $350
    Unipro water temp cables #11-02-001 new (2 available) – $25 ea.
    Unipro water temp cable + sensor kit #10-09-001 new – $85
    Unipro speed sensor + cable kit #10-04-001 new (2 available) – $100 ea.
    Unipro RPM sensor + cable kit #10-08-001 new – $70
    Unipro CHT sensor + cable kit 2.0mm / 200 deg #10-11-001 new – $100
