Home Forums TaG Rotax Max My rotax needs water pump gaskets need a good shop
This topic contains 3 replies, has 3 voices, and was last updated by  Simon P Lesada 3 years, 6 months ago.
  • #48991
    Simon P Lesada
    Hello everyone my rotax sr started to leak water into the gear case, i just had the top end done so thats fine, i need to send my motor to get all the lower end gaskets and water pump replaced any good shops to send it to? Thanks i can ship the motor no problem i live in Milwaukee Wis
  • #48995
    Peter Zambos
    L.A.D. Specialties
    I’ve been their customer for decades and they do excellent Rotax work. They’re in Bridgeview, IL, so you could drive there, otherwise the close distance will cut down on the shipping charges.
    ladspec.com
  • #49026
    Curtis Cooksey
    It is a pretty simple fix, but you do need to split the cases. Any Rotax Service Center should be able to do it and tell you how much it will cost before you ship your motor to them. Sounds like L.A.D. is close to you and that can save you money and time.
  • #49034
    Simon P Lesada
    Thanks everyone ill email Lad and get this motor back on the track.
