--> Mxc vs Mxp – ekartingnews
Home Forums Chassis & Handling Mxc vs Mxp
This topic contains 5 replies, has 3 voices, and was last updated by  TJ Koyen 3 years, 1 month ago.
  • #43959
    Mark Parker
    how do you figure out what’s best and when or if you have mxc do you just roll with mxc?
  • #44074
    Mark,
    I run MXCs almost all the time. I’ve had them work just fine in 40˚ weather on hard tires, as well as 90˚ weather on soft tires.
    I would say in general the MXPs won’t hurt you unless you’re on a medium/soft tire or at a regional/national race.
    The MXCs will always provide an advantage in terms of tire consistency. If you’re struggling to get the kart to work consistently through a run and it’s dropping off too quickly at the end, that’s the point the MXCs are your optimal wheel.
  • #44109
    Mark Parker
    Thanks TJ. Are mxp ok for rains or do i need to all aluminum ones?
  • #44136
    I prefer aluminum for the rain just because rain wheels tend to take some abuse, and also aluminum tends to give the tire a bit more grip.
  • #44156
    Brock Weiss
    TJ what are MG yellow tires considered? Soft or hard and would MXC wheels work for them at a club with eight laps??? If they do great!
    If they don’t then crap! I’m out $700
  • #44243
    Brock,
    Yellows would be considered a softer tire here. And yes. MXC wheels will always work.
