Home Forums General Karting Discussion Moving in the seat
This topic contains 2 replies, has 3 voices, and was last updated by  TJ Koyen 1 year ago.
  • #76889
    William Weiler
    When I watch racing, people don’t seem to be sliding around in the seat, yet my instructor said to slide to the outside of the seat and actually move my body in turns to get more bite. I thought the seats were supposed to be a tight fit and everything, including the seat, flexed to transfer weight. Is it both?
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
    #76890
    FREDDY SANDOVAL
    William, you are correct.
    Your instructor wants you to utilize your body weight to the desired area you want the kart to bite, for your personal advantage, this doesn’t mean you have to slide side to side, just squeeze your body into a corner of the seat. Tilting your head and neck will also help.
    #76910
    Your instructor is correct. The kart needs weight transfer to flex and work properly. Your body is the biggest weight in the kart. By moving around in the seat and changing your posture you can completely change the attitude of a kart. A poor handling kart can be fixed mid-race just by changing your position in the seat.
    The seat will be tight when you sit in it on the grid. But remember, you’re approaching 2-3 Gs in the corners so your body is going to compress pretty heavily under load. This means you’ll have some space to slide a couple inches side-to-side in the seat in the corners.
    If you lean to the outside of the seat with your body, you create a more direct connection from seat to chassis and help put more load on the outside tire. This will help the outside dig in and lift the inside rear more effectively. Conversely, leaning into the corner will do the opposite.
    Posture is one of the most important driving skills to learn in karting. I preach about it endlessly when I coach.
    Here’s a couple images that demonstrate leaning to the outside of the seat for more weight jacking to the outside corner:
