Home Forums General Karting Discussion Motul Oil Bottle
This topic contains 2 replies, has 2 voices, and was last updated by  Ray Chiappe 3 years, 1 month ago.
  • #39849
    Ray Chiappe
    Anyone besides me get upset with these bottles? Can they make it any harder to open? Especially when it’s cold! They should just hand them out with a pad lock and no key!
    #39915
    Charles Kaneb
    A flathead screwdriver helps. If it’s so cold that the plastic’s brittle, then what are you going to run in the radiator, and what’ll you do for tires?
    #39931
    Ray Chiappe
    It was about 45 degrees in my garage the other day when I had to open a new bottle. Had a race on Sunday and needed to mix up a couple of gal. I was using a screw driver to pull out the cap and it wouldn’t pop out, the cap came off without turning it!! About hit myself in the chin! I guess I need to use a heat gun!
