--> Misc. CRG chassis/shifter/Leopard parts – ekartingnews
Home Forums Classifieds Classifieds – Parts Misc. CRG chassis/shifter/Leopard parts
This topic contains 2 replies, has 2 voices, and was last updated by  J.C. Peterson 4 years, 3 months ago.
  • #15252
    J.C. Peterson
    Cleaning out the trailer! PM me for more details & photos. All CRG chassis parts are from an older Blue Demon. Leopard parts are all Pre-MY09. All reasonable offers will be taken.
    – Leopard crank/rod – Clutch side damaged
    – CR80 crank/rod (rod will likely need replaced but crank is good)
    – CR80/85 o-ring exhaust manifold
    – CRG front nerf bar
    – 40 mm Righetti Ridolfi axles (B compound – Medium)
    – IAME exhaust tip
    – Leopard exhaust header w/ EGT port
    – Leopard blue ignition coil
    – Exhaust flex wrap (8″ long)
    – Leopard 10 tooth clutch sprocket (aftermarket)
    – Leopard starter adapter drive
    – Leopard ignition rotor
    – Pre-MY09 Leopard cylinder head
    – Complete Leopard push-button wiring harness and ignition stator
    – CRG 2000-up brake caliper mounting bracket
    – Birel “Banana” rear brake pads (2008+) – Sinter Red Carbon 222
    – CRG 100 cc spindles (left & right) – 17 mm w/ 8mm kingpin bolts & new bearings included
    – CRG 4-position camber/caster pills (8 mm kingpin)
    – CRG front wheel hubs – 17 mm x 80 mm (CRG wheel pattern)
    – 40 mm axle shifter sprockets (428 chain): 22 & 23 steel / 27, 28, 29 aluminum
    – Righetti Ridolfi rear bumper mounts (plastic bumpers) – 30 mm chassis
    – 40 mm axle hubs: 100 mm (2 ea.),
    – 50 mm x 85 mm Freeline axle hubs (2 ea.)
    – Douglas aluminum front wheels (CRG pattern- 5″ width/2.25″ backspace): 4 ea. black / 2 ea. polished
    – Douglas aluminum rear wheels (7.75″ width/2.5″ backspace): 2 ea.
    – 40 mm axle sprocket carrier
    – 50 mm axle sprocket carrier
    – Leopard starter (needs brushes)
    – Odenthal 10 deg. Tag engine mount (& vibration plate)
    – 219 chain breaker tool
    – Leopard reed cage (complete) – reeds will need replaced
    – 40 mm axle plastic water pump pulley
    – Leopard clutch cover w/ coil mount
    – Slant-style sidepods (complete)
    – Black  Freeline-style nose w/ CRG decals
    – Red Freeline-style nose (blank)
  • #15527
    Tony Lischak
    I’m interested in the Odenthal 10 deg mount can email me pictures and price kkartsport@yahoo.com
  • #20322
    J.C. Peterson
    Bump
