Home Forums General Karting Discussion min/max wt and cht setting for cr80 on mychron gold
This topic contains 0 replies, has 1 voice, and was last updated by  Sebastian Sarmiento 3 years, 9 months ago.
  • #34527
    Sebastian Sarmiento
    Hi, I just bought a used Mychron gold from Ebay and installed it successfully on the kart.
    Now I want to set up the low/high water temps and CHT alarms. Also the shift light, as you enter into that menu says:  08401, 09200, 10200, 11200, 13200 , even after clearing the data, they still there (may be factory set?, do I need to choose one?) It also says max rpm alarm, what should I set everything at?
    I’ve reading the manual, but I’d like your input on how to set up the mychron.
    As far as I know the CR80 is stock.
    Thanks for your help.
    I wish you twice as much of whatever you wish for me. : )
