Home Forums Chassis & Handling Middle bearing question
This topic contains 8 replies, has 5 voices, and was last updated by  Daniel White 2 years ago.
  • #66252
    Daniel White
    I race Yamaha and use a 50mm axle (if that makes a difference).
    Is there a handling difference between merely zip-tying the middle bearing and removing it altogether?
  • #66262
    Nope.
  • #66284
    Gary Lawson
    About 2 pounds if you take it out. Otherwise no.
  • #66289
    Matt Martin
    Without the hanger there, you’d get rid of parasitic losses from the bearing having to rotate.
  • #66301
    Daniel White
    Thanks for the replies.
    So if it were you (or me), a 5-11, 162-ish driver racing Yamaha spec pipe / can, would you take out the middle bearing or leave it in?
    When I got the kart, I took it out, but my racing friends tell me to put it back in. Their argument is that having it in gives me more tuning options. My counter to that is if I want to tighten up the rear, I can
    1. narrow the rear track
    2. tighten the bolts to my rear bumper
    3. install my rear torsion bar
  • #66310
    Well option 3 should be the very last resort on any kart. 99% of people throw out their rear torsion bars.
    I like having it in because it’s a quick little adjustment to see if you need to go stiffer on the axle. Put the bolts in and see if the slight stiffening helps the kart.
    Options 2 and 3 on your list involve stiffening the actual frame from tube to tube. I like to have an option to stiffen the axle too, as that can have a different effect to stiffening the actual frame.
  • #66836
    If you have a hard high speed braking zone, the rear of the kart might go all wonky without the middle axle bearing depending on the track and traction you might flip.
  • #66871
    I seriously hope that’s a joke Gif.
  • #66994
    Daniel White
    I haven’t flipped, but I will say that my local track has a hairpin-ish turn, and I swapped ends three times this past weekend. The kart didn’t swap ends on initial braking, but late in the zone, just before turn in.
    Now, perhaps this was because I may have started the turn before my kart had slowed enough, but I’ve driven this track for eight years and have rarely had this much trouble.
    Maybe the middle bearing, even just zip tied, provides a bit more stability under braking, no?
