Home Forums 250 Superkarts Metric Wheels
This topic contains 5 replies, has 4 voices, and was last updated by  Alan Sheidler 4 years, 1 month ago.
  • #17327
    Alan Sheidler
    Is there an easy source for the 6″ metric wheels, which I am assuming are what is commonly run on many of the Superkarts?
    #17340
    Ian Harrison
    Alan,
    Not sure what dimensions you are wanting metric??
    Superkart tyres are sized in imperial units i.e. 5.00″ wide x 6″ dia, 5.50″ wide x 6.00″ dia, 8.00″ wide x 6″ dia, 8.10″ wide x 6.00″ dia. etc, etc.
    Wheel widths will be referred to in either inches or mm (approximations) depending on which part of the world you come from i.e. 8″ wide = 200mm, 5″ wide = 120mm etc.
    The main manufacturer of Superkart wheels is Ross Edwards in Australia. I believe that they are imported into the US by Burris????
    Best Regards
    Ian 🙂
    #17341
    Alan Sheidler
    I should have been a bit more specific: The Metric part refers to the bolt pattern for attachment to the hubs.  In the States, there is still a huge portion of the sport, fairly collected in the circle-track segment, which uses inch fractions measurements.  The wheels for each (Euro = Metric, American = Inch) are sport segment specific, although crossover is always possible.
    So, what I want to know is:  Where can I go most easily (website with online ordering?) to obtain 6″ Metric bolt-pattern kart racing wheels?
    Thanks for the reply Ian.
    #17346
    Gerry MCN
    John Benson
    Burris racing
    #17366
    Alan Sheidler
    Thanks!
