--> ME Shifter F1 setup – ekartingnews
Home Forums Shifter Karts ME Shifter F1 setup
This topic contains 2 replies, has 2 voices, and was last updated by  Lausan Foster 2 years, 3 months ago.
  • #61173
    Lausan Foster
    I have the ME shifter paddles on a CKR steering wheel, but realized halfway through the install that the CKR hub doesn’t have a way to attach the clutch? Any ideas on attaching a clutch to a hub that doesnt have the normal holes? I realize i could just use the stock OTK wheel and hub, but that would negate the  almost 400 I spent on getting the CKR wheel and hub shipped from Germany.
    Swift
  • #61180
    William Martin
    Can you post a picture of the set up that you have? I made my own clutch handle perch to stop the flapping cable issue, whenever turning the steering wheel. It goes on the steering column between the steering wheel and the upper column support, but it floats on the column, not turning with the steering wheel. Not sure if this is what you need, hence the request for a picture of what you have now.
    • #61183
      Lausan Foster
      ill try and get a pic up in the morning.
