Home Forums Shifter Karts Maxter Parts
This topic contains 5 replies, has 4 voices, and was last updated by  Frank Rapisarda 4 years, 8 months ago.
  • #22290
    Dan Helman
    Hello Everyone
    I’m a little new to this. Can someone point me in the right direction for Maxter parts in the Georgia area or on line?
    Dan
  • #22294
    Jimmy McNeil
    Hi Dan, give Swedetech racing a call. If they don’t have the parts, they can definitely aim you in the rite direction.
    They built a Maxter for me a couple years ago to use at the National finals, It was so dominate, it was almost unfair lol.
    -jim-
  • #22300
    James McMahon
    Swedetech
    PSL (Canada)
    Joe White
    Depending on what you need exactly other brand parts may work too.
  • #22401
    Frank Rapisarda
    Hi Dan, I just got a maxter myself, swedetech has the parts but they are not cheap. I think I will stay with my mod moto motors, the parts are so much cheaper.
  • #22411
    Dan Helman
    Thank You for the info. I just got the kart for my son. He ran TAG for 3 years and wanted to try shifter. We ran an Un sealed Rotax. I’m a heavy truck mechanic by trade and I had no trouble doing the work on the Rotax because the parts and service information are readily available. I’m finding that Maxter is more of a mystery there isn’t much in the way of service manuals or information I found some parts diagrams but that’s about it. The engine runs fine and supposedly has low time on it but I’d like to do a top end to have a starting point.
    I’m assuming it’s basically the same procedure as the Rotax But any tips or info would be appreciated.
    Thanks   Dan
  • #22604
    Frank Rapisarda
    Dan taking it apart shouldn’t be a problem for if your a mechanic. I haven’t taken mine apart yet, but I was a motorcycle mechanic at one time, they are all close to the same. the one thing you want to make for yourself is a box made from a 2×4’s standing up on the 1 1/2 side. ( 12″ x 11″ ) Take the clutch side of the motor apart first then flip it over and split it from the ignition side. Make sure you tap on the countershaft (drive – output shaft ) so the trans doesn’t fall out, and pay attention to make sure if the trans lifts out of one of the bearings that you don’t drop a washer if it has any.
