--> Master Cylinder – ekartingnews
Home Forums Tech Talk Master Cylinder
This topic contains 4 replies, has 3 voices, and was last updated by  Walt Gifford 3 years, 11 months ago.
  • #28854
    michael smith
    Hi all,
    first time karter. I got a veloce 125 cc frame from someone. he had taken off and sold the front brakes but left the dual master cylinder with balance adjustment . I plan to only run a rear brake. would I be better off just getting a single master cylinder for the single rear brake?
    if yes, are they pretty universal and can I get a recommendation on one?
    thanks all
  • #28856
    michael,
    know nothing about a veloce chassis, but are you sure you don’t have two master cylinders bolted together? If you do, remove one and the bias adjuster. You’ll probable need a new brake rod as well.
    http://www.tsracing.com/Manuals/Veloce/VeloceMasterCylinder.htm
  • #28863
    You have 2 master cylinders on the kart now? Take one off and get a new brake rod to the other one.
  • #28884
    michael smith
    wow, thanks guys. I went back and looked and it sure does have TWO master cylinders. that saves me some money right there.
    while I have your attention, I need a caliper because the chassis did not come with calipers. TS racing sells the specific one for the chassis (skm , 60-mm centers on the bolts and the rotor is almost 12mm thick. should I get the factory one or are there brakes out there that may be better performing?
    thanks
  • #28947
