Home Forums General Karting Discussion Master Cylinder Lever Adjustment
This topic contains 3 replies, has 4 voices, and was last updated by  Peter Zambos 4 years, 11 months ago.
  • #19303
    Josh Hovermale
    New to karting, so looking for an answer to what might be a no-brainer.
    Looking at the Master Cyl lever, there are three holes available to mount the rod that connects to the pedal.  What would changing the hole do?  Less pressure, or change engagement point?
  • #19307
    Jim White
    It’s going to change the length of throw at the pedal. If you like a real “short” pedal (applies quickly and rapidly) put it at the bottom. If you like a “long” pedal (more travel) put it at the top. Since it’s easy to change try it both ways back to back and see what you like. I’m most comfortable with a very short pedal  but I’ve got a buddy who likes his the other way. I can’t hardly drive his kart. It just seems as though you push and push and push then they finaly grab.
    Placement will effect the needed pressure but it’s very little and I’d be surprised if you’d even noticed the difference.
  • #19315
    Gary Lawson
    The connection point will make considerable difference on braking power along with the change in throw as correctly mentioned above. The highest hole on the arm will give most braking power. The opposite holds true for the connection point at the pedal.
  • #19538
    Peter Zambos
    No offensive to Jim, but in my experience, the position of the rod upon the master cylinder lever makes a considerable difference in brake effort and feel.  It’s basic mechanical advantage stuff.  The higher you go on the lever, the easier it will be in terms of over-all force required, but the pedal will have to travel farther.  Due to the need for more pedal travel on the higher point, drivers tend to report an increase in pedal “feel.”  It’s a driver preference, but getting it to where the driver likes it can result in better lap times.
