Home Forums Chassis & Handling Massive front end grip
This topic contains 7 replies, has 7 voices, and was last updated by  Patrick Roth 3 years, 4 months ago.
  • #44381
    Brock Weiss
    can anyone tell me what you can do to take away front end grip? My kart has massive front grip and I am not sure how to take grip out of the front end
  • #44391
    Gary Lawson
    Man up and drive it if it’s at the factory recommended setting. Lol. I’m just joking but it’s probsbly what would actually be best. I would think you need to get used to driving the kart as is. IDid it truly is excessive then less caster and/or softer front bar will help. I/we surely don’t mind answering your questions but if I just bought a new kart I would be talking to the people that sold it to me.
    • #44393
      Brock Weiss
      Thanks I will let my son know just to drive it and deal with it. Just gonna cost me a lot in tires
  • #44394
    The closer you have the front hubs together on your spindle the more front grip you have, the further you space them apart from each other the less grip the front end has, Try adjusting the front hubs, I had the same problem on my gp kart
  • #44396
    Jarrett Lile
    If he needs a big change try lowering the front end ride height by raising the spindles a spacer or two.
  • #44397
    Jimmy McNeil
    Not sure what chassis your on so your results may vary.
    Take out caster (move top of king pin forward), narrow front end will reduce oversteer on entry but may increase oversteer on exit. Lower front ride height, stiffer axle, softer or remove front bar, tighten rear bumper, if it’s extreme, I would move the seat back.
    Hope this helps.
  • #44408
    Just wanted to note that this is incorrect. A wider front track width will give you MORE front grip. A narrower front track width with give you LESS front grip.
    Brock, you already know my reply.
  • #44418
    Patrick Roth
    Brock,
    How much experience does your son have driving it? What are the indicators that there is too much front grip and at what point in the corner?
