--> Looking to run some long track – ekartingnews
Home Forums Road Racing Looking to run some long track
This topic contains 5 replies, has 6 voices, and was last updated by  Peter Zambos 4 years, 3 months ago.
  • #19844
    Jason Ewers
    I’ve been sprint racing for years and thought I may dip my feet into a few long track races in the midwest with my tag. What would I need to accomplish this. Do I need full body work.  Thanks
  • #19847
    Ray Chiappe
    Depends on the class you run on the type of body work.  But there are plenty of Sprint classes avail. that use stock sprint plastic! The main thing you will find very different is the gearing.
  • #19853
    Jeff Salak
    To go from Tag Sprint to Road race isnt much to do. Gearing change like Ray said for most Tag engines and tracks this will be a 16T driver and sometimes a 15T. Lay back your seat so your not sitting so upright. Front brakes are always good to have.
    What Tag engine you run? If you run a Leopard you may want to get a road race clutch.
    What series do you plan to run with?
  • #19897
    Kelly Read
    Jason,
    Before you go and make changes to the kart, you might want to check on the rules in the area you plan to race at. Not all orgs allow the seat to be laid back. If you plan to run a KART/MARRS event, I can help you here.  This series races in Ks., Ok., Ne. Around here we all run a 16 tooth front gear. We have ran both the sprint & R.R. hub and biggest difference we seen was that the R.R. hub lasted longer.
  • #19903
    Keymaster
    Jason,
    Like it was mentioned already: Check the rules with what race you plan to compete in, and get a 16T driver.
    If you run WKA, you need dual-brake system. Which means two separate brake systems, either two rear or one front/one back
    If you run CES, you won’t need to worry about the extra brakes.
    I suggest Grattan and Gingerman. Both require you to drive well.
  • #19907
    Peter Zambos
    Jason, if you’re going to the Springfield show this Sunday, pm me and we can talk at length about road racing in the midwest at the show.
