--> Leopard Won't Idle – eKartingNews
Home Forums TaG Leopard Won't Idle
This topic contains 7 replies, has 4 voices, and was last updated by  Steven Kay 3 years, 1 month ago.
  • #47414
    Steven Kay
    I can’t get my ’09 Leopard to idle.  It starts with a little hand choke and just screams.  I just checked the pulse path and reeds.  All were perfect.  Throttle is closed as normal.  Any thoughts?
  • #47419
    Ric mcDade
    Air leak
  • #47424
    +1 Yup, you’ve got an air leak somewhere.
    • #47428
      Steven Kay
      Thanks guys.  I just had the carb off and the reed box out.  It doing the same thing before and after.  Any thoughts on other areas to check?  I seem to have good compression.  One more piece of information.  I had to pull the fuel line to get it to shut off.  Neither the ignition switch or the pulling the battery terminals would get it to shut off.  Probably ran a good 15 seconds after pulling the fuel line.
  • #47443
    Jim Derrig
    Sure sounds like an air leak, especially with the dieseling. It continued to run because that’s how long it took to empty the gas from the carb.  Guessing one of the carb gaskets, or the o-rings on the mixture screws might be bad.  Also, is the butterfly valve stuck open?  Try swapping out the carb and see if the problem continues.
  • #47496
    Steven Kay
    OK, still cant seem to find the leak.  Could it be that I need to disassemble and soak the carb gaskets as I didn’t run this engine last season and this is the initial start-up?  “Trying to learn on the job”
  • #47508
    Jim Derrig
    Put a rebuild kit in it, as it’s probably past due anyway.  You’ll need to order the mixture screw o-rings separately.
    Tillotson Carburetor Rebuild Kit
  • #47515
    Steven Kay
    Yeah, I just ordered a kit plus the packing’s and reed and intake manifold gaskets.  Thanks Jim
