--> Leopard Difference??? – ekartingnews
Home Forums TaG Leopard Difference???
This topic contains 4 replies, has 4 voices, and was last updated by  Michael Rutter 4 years, 4 months ago.
  • #17367
    Chance Barthold
    I am looking at getting a TAG leopard engine but how can you tell if it’s a MY09 engine or one that’s older than that?  And what exactly is the difference?  Thanks in advance for the help.
    Chance
  • #17372
    Gary Osterholt
    Pre 2009
    MY09
    MY09 and newer.
    The easiest way is to look at the clutch cover.  The MY09 has a 3rd bearing built into the clutch cover.
    Gary Osterholt
    GO Designs, LLC
    http://www.godesigns.us
  • #17373
    Chance Barthold
    Can you tell from this pic which style it is?  The only difference i see from your pics above is that the newer models are covering the clutch area more.  Is that what you were talking about?
  • #17381
    Josh Buttafoco
    Carb is at an angle for the 09′, straight on the 08′.
  • #17638
    Michael Rutter
    They key way to tell is by the carb angle, if it is a MY09 it should be on an angle with the blue pointing towards the side-pod, also the crank will be a rectangular shaped end not a starter nut or nut.  The motor pictured above is a Pre-09 which aren’t as competitive so I hear.
