--> Leopard battery – ekartingnews
Home Forums TaG Leopard battery
This topic contains 3 replies, has 4 voices, and was last updated by  Bob Wimmer 4 years, 1 month ago.
  • #25187
    Joe Brittin
    Looking for a better battery for the MY09 Leopard. Bought a new FIAMM 12FGH36 and it does not seem strong enough as it barely turns over the engine. A heavy battery is fine as we add a lot of weight.
  • #25218
    Joe,
    Think your issure is that battery was designed for a UPS, not as a power soure are a starter. I tried batteries from a battery store, not good results.  The price is great.  Able to start your engine, questionable.  Wasn’t designed to be rattled around in a kart. Very short life cycle.  Comet lists an orginal replacement battery.  It will only be heavier on your wallet.  But it will turn over you engine and it will last.
  • #25223
    Eric Stevens
    I think you have a bad battery or a poor connection somewhere in the system. I have a 7 amp hour version and it works just fine on my leopard even after months inbetween sessions as long as I disconnect the battery during storage.
  • #25453
    Bob Wimmer
    I have had good luck with ups batteries when the Leopard charging system is maintaining 13+V.  If it drops below 12.5v  battery life suffers. Double check charging voltage before replacing. <span style=”color: #333333;”><span style=”background-color: rgba(255, 255, 255, 0);”>
    </span></span>
    Good luck
    Bob
