Home Forums Chassis & Handling Leg / throttle cable interference
This topic contains 1 reply, has 2 voices, and was last updated by  Eric Stevens 3 years, 8 months ago.
  • #38031
    Kenneth Culver
    I have a birel and the throttle cable is exposed from the pedal back to about the center of the gas tank area.  I have a problem especially in left hand turn with my leg hitting the cable and applying  throttle accidentally.  It seemed like a poor design to have the cable exposed like that.  does anyone else experience this problem?  Are there any solutions available?
  • #38034
    Eric Stevens
    I move the throttle cable on all my Karts for the same reason.
    I mount an L Bracket to the top front bar mount just above and behind the throttle and drill and tap a hole in it for the cable adjuster with cable exit angled towards the pedal as needed. I then route the cable sheath through the origna cable adjuster threaded hole to the new location.
