Home Forums Tech Talk Leak Down – What Is It?
This topic contains 8 replies, has 6 voices, and was last updated by  Greg Wright 1 year, 9 months ago.
  • #64042
    The USPKS/Route 66 series posted a message that engines will be checked for leak down. What is leak down and how is it checked?
    #64044
    Matt Martin
    if that’s all it is, that’s great. Can’t see how an engine with a single piston ring wouldn’t leak and still run. Yes, we’ve melted a couple pistons so well into the bore that they probably had zero leak down.
    Thanks Matt
    #64076
    Greg Wright
    Actually I think they are looking for air leaks. On engines with restricted carburetion example Yamaha Jr, Sportsman with the WB55 carb and also with Comer K-80s some builder have intentionally leaked air to the engine via intake manifold or crank seals. More air=more fuel+more power. They can be a bitch to start though.
    Greg Wright
    Rapid Racing Inc.
    #64078
    Keymaster
    What Greg said. I just learned about it myself.
    #64089
    Greg, David, Matt,
    Thanks for the responses.
    #64111
    Timothy Strawkas
    Ever notice the smell of starter fluid on the grids has become stronger and stronger over the yrs. This is the leading cause of the source. Not the only reason mind you, but…
    #64180
    Bill Angel
    From what I hear a tech update from WKA on leakdown is coming soon.
    #64181
    Greg Wright
    I believe that IKF installed that rule a few years ago.
    Greg Wright
    Rapid Racing Inc.
