--> kz engine mount – ekartingnews
Home Forums Tech Talk kz engine mount
This topic contains 1 reply, has 2 voices, and was last updated by  Glenn L Riggs 1 year, 11 months ago.
  • #66991
    Cody Elliott
    Could someone tell me what the advantage is to having an angled engine mount for a kz, and how much of a degree I should look at? I heard that it helps with bottom end a little bit but helps keep the carb more level. Would it be worth doing?
    Thanks!
  • #67022
    Glenn L Riggs
    The mount was designed for the k9 series to get a better fuel displacement angle the newer kzs engines have that angle built into them not needing the front end raised the kz10c is supposed to be slightly higher than the kz10b dont think there is much performance difference tho hope this helps
