Home Forums Shifter Karts KX 250f 4-Stroke Drive Gear
This topic contains 4 replies, has 4 voices, and was last updated by  Chris Reinhardt 4 years ago.
  • #34625
    J.R. Ybarra
    Need a little help from anybody who has done a four stroke shifter, I have a Kx250f four stroker that I have on chassis, (unfinished project from another owner), and it has the stock drive gear which is meant for a 520 chain and I am needing a drive gear that is for the more commonly used 428 chain. Anybody know if the KX 2-stroke gears will work? or can something cross over from another manufacturer? Anybody known where I can purchase? Thanks!
    JR
  • #34640
    johnny brooks
    These guys could probably make what you need:
    http://sidewindersprockets.com/
  • #34674
    J.R. Ybarra
    Thanks Johnny, that looks like a great resource
    JR
  • #34681
    It’s probably not made so you’ll have to make it. Take your gear and get a machine shop to cut it down then make a spindle and weld a 428 sprocket to it. I had to do that when I put together a CRF 450 Kart.
  • #35326
    Nobody custom makes counter shaft gears, Sidewinder uses somebody else counter shaft sprockets I believe…
    Best bet like Brian said, cut up some stock sprockets and buy some CR125 428’s and have them welded up…
    I do them here all the time…
    This is one I did for a dyno project…
    XV Racing Products
    http://www.xvengineering.com/
