Home Forums General Karting Discussion KT100 Rebuild Cost
This topic contains 17 replies, has 7 voices, and was last updated by  Daniel White 1 year, 4 months ago.
Viewing 18 posts - 1 through 18 (of 18 total)
  • #71643
    How much are you guys paying your trusted engine builder for a full rebuild (no blue printing) including con rod on a Yamaha KT100? I’ve heard of crazy prices like $700. Parts are like $300 retail so that’s like $400 labor??
    #71718
    Daniel White
    I’ve been racing KT since late 2012, and have had just 3 rebuilds, usually after 7-8 hours. I don’t think I have ever paid less than $700. One time I had to have a new crank half, and added a can carb (I already had a SR-Y pipe-prepared carb), along with my rebuild, and it came to $1000.
    #71775
    Yeah, I’ve been calling around and that’s about right. The amount of money businesses have to charge to keep the doors open these days is just crazy. I’ve been charging my buddies 450 total and to think kart shops get parts wholesale and I don’t. Glad I build my own, that labor charge is a big expense.
    #71813
    Aaron Hachmeister
    I figure it’s probably pretty dependent on if anything’s wrong with the engine. I know Comet Kart Sales charges $200 for labor every time, and my builder has given us anything from $300 to $750 depending on damage. If the crank got knocked out of alignment or if I over-revved the engine on accident and the piston hit the top of the cylinder it’d obviously be a little more.
    #71842
    Ray Mcik
    With the cost of a shop etc etc and taxes they have to charge   to keep the lights on . since when did profit become a dirty word ?
    do you know what a auto shops hourly rate is nowadays ?
    #71848
    Daniel White
    I raced Rotax from 2008-2012–and had the motor rebuilt once (after 33-ish hours) for about $1100. I’m guessing the motor was about $2600 (I bought it as part of a package, and it had just had a complete rebuild)
    I’ve spent $2500 for my Yamaha rebuilds, and am due for another rebuild at the end of the season. I’d say that I have about the same time on my KT as I did my Rotax.
    My point is that I think the Yamaha is more expensive than the Rotax.
    Now, having said that, I never spent the resources in Rotax to make sure I was jetted correctly, and was never competitive–not even close. But I was immediately fast (enough) in Yamaha (the first race I was within a tenth of pole), and am extremely happy with my engine builder.
    #71855
    I know Comet Kart Sales charges $200 for labor. If the crank got knocked out of alignment it’d obviously be a little more.
    Talking about replacing the rod so the crank’s coming apart. Comet and others told me 300-350 labor for a full rebuild which seems to be par for the course. I’m not knockin’ anybody making a buck, I’m just asking.
    #71888
    Greg Wright
    Daniel White, You paid $2500 to rebuild a Yamaha, I would have built you two new ones for that amount of money. They must have seen you coming.
    Greg Wright
    Rapid Racing Inc.
    #71909
    Daniel White
    Read the entire thread. The $2500 was an approximate figure for 3 rebuilds– including an additional carburetor and a new half-crank–over 3 years.
    #71937
    Greg Wright
    Still high.
    Greg Wright
    Rapid Racing Inc.
    #71943
    Daniel White
    Maybe. But it wasn’t $2500. And Walt mentioned that he’s done some asking around, and found that my figure was “about right.”
    Unfortunately, I’m neither a builder nor a mechanic, so my options are limited.
    I may take a chance someday on a motor by a less well-known builder (who charges less)–I’m not against it. However, when I first got into the KT class, I was referred to a builder by a competitor who is well known and respected, so I went with his suggestion. Because I have been satisfied with the performance of my engine, I gave that builder my business again and again.
    Your particular insult was uncalled for, since we’ve never met.
    #71976
    Greg Wright
    No insult was intended in any way, sorry you took it that way.
    One question though, you say it was $2500 then you say it wasn’t $2500. I guess my reading comprehension is lacking somewhere.
    Greg Wright
    Rapid Racing Inc.
    #71979
    Steve Frank
    I just did a rebuild on a friend’s Yamaha rookie motor.  Parts cost was under $200 with a few carb rebuild kits etc.   The crank was among the straightest I’ve seen (less than .0005″ on each side) and the lower rod bearing had virtually zero play so we didn’t separate the crank.  We did new main bearings, seals, cylinder hone and top end, along with measuring /checking to be sure the port timing and cc’s matched the engine builder’s specs.   In all, it took about 5 hours labor.  Still a pretty cost effective engine package in my opinion.
    #72578
    Jim Howe
    I pay anywhere from $300 – $600, depending on what all needs to be done. Dyno time is extra, of course, as is any machining if needed on a non-blueprinted engine. And I think that’s pretty much standard for all the engine builders in my area, big and small. So, I consider this pretty darn reasonable myself.
    #72683
    Daniel White
    No insult was intended in any way, sorry you took it that way. One question though, you say it was $2500 then you say it wasn’t $2500. I guess my reading comprehension is lacking somewhere.
    In my first post in this thread, I stated that I have had my Yamaha rebuilt 3 times since 2012. I then stated that one rebuild was $700. I also stated that I had another rebuild, but it included extras, and came to $1000. I never mentioned the price of the 3rd (but my memory recalls a broken wrist pin which came loose and scraped the heck out of the cylinder wall, and the resulting damage caused my rebuild price to increase).
    Then, in my second post, I mentioned that my rebuilds (plural) came to about $2500.
    In my view, this wasn’t too difficult to follow.
    #72694
    Greg Wright
    Gee, give it a rest. I already said that I had misunderstood your post and apologized for it.
    Damn!!
    Greg Wright
    Rapid Racing Inc.
    #72695
    Broken wrist pin? like it broke in half? That motor must have been a box full of twisted shrapnel.
    #72721
    Daniel White
    Broken wrist pin? like it broke in half? That motor must have been a box full of twisted shrapnel. Gif
    Crap. I mis-remembered. It was the circlip holding the wrist pin. It scraped the heck out of my cylinder wall, but my builder saved the motor.
