Home Forums General Karting Discussion KT100 Mount
This topic contains 1 reply, has 2 voices, and was last updated by  Dan Brown 2 years, 11 months ago.
  • #50880
    Does anyone make a flat one piece mount for a KT100 with a third bearing arm?
  • #50900
    Dan Brown
    Walt, I have a couple Odenthal mounts on our Margays with KT100’s that have very little angle to them, maybe only a couple degrees. I also have a two piece kt100 mount that has the third bearing support that is flat that I installed on a spare backup engine. I have 2 or 3 other mounts that came with a couple kt’s I bought, cant remember if they are flat or angled. I will check and let you know. What I have found is with the flat mounts it is more difficult to get the header/pipe mounted up without having interference from the rear bumper, the angled mounts kick the pipe up much higher at the rear of the kart.
    Dan
