Home Forums 2-Cycle Racing KT100 base gasket and port timing
This topic contains 1 reply, has 2 voices, and was last updated by  Walt Gifford 4 years, 6 months ago.
  • #29629
    Art Serna
    Can someone explain the effects of using different thickness cylinder base gasket.
    I have been told thinner gasket moves power band lower, thicker gasket moves it higher in the rpm range. Is this true , is there a good starting point or is it just trial and error until you find what works?
  • #29886
    There’s no significant change in performance. Just optimize the timing based on the WKA rule book.
