Home Forums Tech Talk KT100 Backfire
This topic contains 4 replies, has 2 voices, and was last updated by  Thomas Salandra 4 years, 1 month ago.
  • #26911
    Thomas Salandra
    I have a KT100 engine that backfires. It shoots fire out of the carb and exhaust. It is a redone motor with no hours on it. There is a 4 hole can on the back. I changed every part on it with a  motor that I also rebuild and that one ran. I would like some help if any one knows about it.
  • #26912
    Jason Ewers
    Your timing slipped when it was rebuilt. Happened to me a few times
  • #26981
    Thomas Salandra
    How do I advance and retard the timing if it is set by the position of the coil and flywheel?
  • #26982
    Jason Ewers
    It’s usually out 180 deg or it has slipped off the crank. I don’t build my own engines but have had this Happen before and that’s exactly what it was
  • #26992
    Thomas Salandra
    The flywheel is out 180 degrees?
