Home Forums Classifieds Classifieds – Parts Kart Garage Sale – lots of enduro stuff, KT100, Mychron
This topic contains 0 replies, has 1 voice, and was last updated by  Chris L Larson 1 year, 3 months ago.
Viewing 1 post (of 1 total)
  • #72499
    Chris L Larson
    KART GARAGE SALE!! I will be attending the KART Grand Nationals this weekend and I have lots of parts to sell at VERY low prices! If you want me to hold something for you to pick up at the track, please send me an email at chris.larson@tronox.com or send me a text at 405-850-6412. I can also ship if buyer pays for shipping. Here is a list of items I am selling:
    Tire mount strap – $10
    Tire bead breaker – $15
    Tire mounting tool – $5
    Tire balancer with weights and extra hubs – $10
    Hunter tire mounting paste (bucket) – $10
    Safety Gear:
    Neck brace – $5
    Simpson helmet bag – $10
    Simpson bandit visors (slightly used) (clear & blue chrome tint) – $5ea
    Sparco rib/back/chest protector vest – $15
    Horstman Axle Clutch:
    Horstman axle clutch – my favorite clutch (last one). Tungsten , and set up info/secretes. – $500
    Horstman parts – all below for $200
    • Springs – yellow, black, Fox Valley
    • Brass weights
    • seals
    • extra housings,
    • friction discs (11 – used)
    • floaters (many- various thicknesses)
    • MiSi – floater scuffing tool
    • Tungsten set
    • Hardware & many various parts
    Belt drive:
    Driver holder tool (modified pliers) – $10
    Driver remover tool (2) – $5ea
    30mm wide stuff:
    Belts – 920 (2), 960 (3) – $10ea
    Gears (40mm wide – split): 70 (2), 71, 72, 73, 74, 75, – $20ea or $120 for all
    Drivers (Yam taper): 14t (3), 15t (5), 16t (4), 17t(1), 18t (1) – $15ea
    20mm wide stuff:
    Drivers (Yam taper) (some new): 15t (4), 14t (4), 21T (1) – $20ea (new) $15ea (used)
    Gears (25mm wide – split): 69-79 (2- 72’s) – most new – $20ea
    Belts: 880 (3), 920 (3) – $10ea
    Spark Plugs:
    NGK BR8EG (Leopard, TAG) (19) – $4ea
    Autolite AR51 (4) – $2ea
    Autolite AR51 (6) – $2ea
    Chassis:
    Throttle & brake pedals – various – $5ea
    Seat mounts (sit up) – $5ea
    Seats (sit up) (3) – $10ea
    Mikuni/Tillotson
    Lots of various parts
    Needle valves,
    Ball valves
    Fuel pumps
    Walbro stuff:
    Pop off gauge(3) – $15ea
    Fulcrum arm height gauge (3) – $4ea
    Carb Rebuild kits (2) – $5ea
    Various hardware – trigger stuff, carb bodies, lots of extras
    Motor mounts
    CKI – Yamaha (4) – $10ea
    Vintage – narrow rail, wide rail, Yamaha, Briggs, Komet, – $5ea
    Butterflies – various – steel, aluminum, narrow, wide – $1pair
    Yamaha KT100S parts
    Left hand starter nuts (2 piece) (2) – $5ea
    Headers – various (6) – $10ea
    TCI (RLV) – new – in box- $40
    Crank & rod assembly – $100
    Pistons
    – Yamaha (4) – $15ea
    – Wiseco (52.85, 53.5) – $15ea
    – KSI – 52.80 – $20
    Rods (3) new – light/medium (?) – $25ea
    Exhaust gaskets (8) – $2ea
    Wrist pins (12) – $5ea
    Upper rod bearings (10) – $10ea
    Aluminum upper rod washers – $5pair
    Phenolic spacer (6) – $5ea
    Rings:
    – OH Gold: 52.0, 52.05 (2), 52.10, 52.5 (2), 52.7, 52.9, + various $10ea
    – Burris: 52.8, 52.4 – $5ea
    Vibration dampners (Cylinder & head) – new & used – $3ea
    Crank pins (2) – $5ea
    Lower rod bearings (8) – $10ea
    Crank plugs (9) – $1ea
    Lower bottom guided washers (6) – $2ea
    Coil wire clips – $1ea
    Rotors – CCW (3), CW (5) – $15ea
    Main bearing spacers – $15 for all
    Case seals (12) – $2ea
    Bearings SKF 6304 (2), ORS 6205 (2), – $5ea
    Hardware (many)– head nuts, cylinder nuts, carb mount
    Studs (many!) – head, cylinder, carb,
    Head gaskets – many – all thickness’s
    Cir clips – many
    Motor bearings
    6205 (SKF) – (6) – $4ea
    6304 (FAG) – (7) – $4ea
    6204 (FAG) – (6) – $4ea
    219 chain Drive
    D.I.D. Chain (NEW) – 114 length – $25
    Chain breaker – $15
    Gears 67,68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81,82 – $5ea or $60 for all
    35 chain drive
    Gears: 63,64, 66, 68, 69, 70 (2), 71, 72, 74, 76,77, 78, 79, 80, 81, 84 – $5ea or $60 for all
    Controlled (Reedjet) stuff:
    RLV IR2 exhaust pipe – $100
    Angled air filters (2) – $5ea
    Headers with EGT bung – (3) – $20ea
    Motor mounts (adapter plate) (2) – perfect offset for CKI left hand drive. $20ea
    Coil mount (to nerfbar) – $10
    Coil ground strap – $5
    Tillotson fulcrum arm pop off spring kit (E.C. Bert) (new) – $20
    Autolite Spark plugs (rare! Discontinued) – 2414 (6), 2413 (1) – $5ea
    Hegar gear drivers (30mm wide)(7/8” bore): 15t (new), 16t (2), 17t (2), 18t (2) – most new. $40ea new, $30ea used.
    Laydown stuff:
    Vintage Coyote Bullet side tanks (1988 era) – $30 pair
    Helmet fairing (New Concept) – $20
    Push stick (2) – $15, $10
    Steering air fairing – $5
    CKI steering shaft – $10
    Trigger/slippy pipe steering wheel mounts
    Catch cans/chain oilers
    RLV Sportsman pipe with flex & header (with EGT bung) – $60 for all
    Exhaust pipes (vintage): – $5ea
    Mayco
    Pitts
    Hartman
    RLV
    17 pipes total
    Kart cover – sit up – $5
    Folding kart stand – chrome, wheels, trey, castors – $75
    Pit board – $5
    Scales (4) (150lb capacity each, digital) – $80 for the set
    Brakes:
    Gravity bleeder – fits MCP master cylinder – $15
    MCP front calipers (gold) – $75set
    MCP black pads front (new) – $25 set
    MCP black pads rear (new) – $15 pair
    Brake line (nylon) – $5
    Bearing cassettes (new) 2 sets – $40/pair.
    Axle bearings (new) (1.25”) (4 pairs) – $10/pair.
    4 Hole Box muffler (new & used) – $30 & $15
    Mychron Stuff:
    EGT sensors (used) (2) – $15ea
    CHT sensor (used) (2) – $15ea
    Speed sensor with axle collar – $25
    Beacon Transponder – $20
    Misc:
    Valve stems – $0.50ea
    Numbers (various) – $0.50ea or all for $10
    Number plates (white, square)- $1ea
