--> KA100 Ignition Cover? – ekartingnews
Home Forums General Karting Discussion KA100 Ignition Cover?
This topic contains 5 replies, has 4 voices, and was last updated by  Ted Hamilton 1 year, 2 months ago.
  • #78732
    Ted Hamilton
    Is there an ignition side cover available for the KA-100?  The exposed rotor and wiring seem like an iffy proposition….Sure, duct tape and zip ties can fix a lot, but just not a very clean solution…  Thanks…
    ~Ted
  • #78754
    Keymaster
    It is what IAME is doing with the new engines. No cover on the ignition side of the engine. Maybe someone can design and manufacture one?
    • #78769
      Dan Breuer
      Hate to admit it but you are correct. Make sure you get the wires up…already made that mistake and had a ‘miss’ all through qualifying (only issue we have had and have run around 8 hours on two engines). Seems like it is going to be a big, affordable class at our track.
  • #78766
    Greg Wright
    Most 100cc reed valve engines (Reedjet, TT75 etc.) have no ignition cover.
    • #78770
      Ted Hamilton
      Greg — yes, but the MOTOPLATS have nice clean wiring…
      I think I’m going to develop a cover since I work at a CNC shop (as a programmer), and I’ll keep y’all posted.  It will be a plate with central hole for the rotor, and a hole to put the rubber grommet plug into that secures the internal wiring…  I’ll post a concept drawing once I have it.  Luckily there’s plenty of threaded locations for standoffs on that side.  I used to work at a small-run plastic injection molding shop as a machinist too, but that road would be too pricey for this limited an application…
  • #78771
    Ted Hamilton
    KA100 Ignition
    Loose wiring…
    The half-moon plug will fit into the cover, which will shield the other two wires from contact with the rotor…
