Home Forums 250 Superkarts ISO…Steering Shaft knuckle
This topic contains 2 replies, has 2 voices, and was last updated by  Brandon Schenkel 3 years, 4 months ago.
  • #43367
    Brandon Schenkel
    like the title states, im looking for a steering shaft knuckle for my Anderson so that i can lower the steering wheel and to fit my short butt better
    thanks
    brandon
    B Stock ............................
    IC/E 250 rookie
  • #43386
    Jim White
    Are you running the rack and pinion steering? If not are you talking about the bearing at the bottom of the shaft or the plastic bushing at the top of column that bolts to the upright?
    If it’s that upper bushing you may be able to turn it upside down if it will clear the shifter boss. Another option is a block of aluminum bored for the shaft and then cross drilled to get it as low as possible. Lots of American karts used the block setup back in the day.
    How tall are you? If you have the bushing in the lowest hole and it’s still to high what about working with the seat instead?
  • #43476
    Brandon Schenkel
    i have a rack and pinion. I already looked at all options of trying to lower the steering wheel but w/ the shifter bracket welded to the steering wheel bracket, i cant lower it anymore, thats why i need a steering knuckle.
    I have contacted Johnny and hes gonna be sending me out 2 knuckles and ill go from there….
    thanks for the help guys!
    -Brandon
    IC/E 250 rookie
