Home Forums Shifter Karts Is this detonation?
This topic contains 5 replies, has 4 voices, and was last updated by  James O’Brien 3 years, 9 months ago.
  • #23983
    Britt Robinson
    I took the head off my modified Honda and found that there is heavy pitting on the cylinder body between the bore and the o-ring, and similar conditions on the head. My initial reaction was corrosion from the cooling system. But then I realized it is all contained in the combustion chamber. These are the best photos I have right now…
    '13 Velox SK1 - CR125 -
    4th place finisher on a good day @ Tri-City Kart Club, Richland, WA
    #23985
    Matt Dixon
    Yes it is…
    94y
    #24000
    Greg Lindahl
    Very much so.
    Check squish.
    Check fuel quality.
    Check timing.
    Check cc’s.
    Check for anything creating lean condition (air leak/carb settings).
    #25118
    James O’Brien
    Yes, most common reason is timing curve. Unless you have some bad or low octane fuel.
    www.eshifterkart.com
    #25296
    Britt Robinson
    James! I should’ve bought your cylinder and cylinder head when I had the chance. I snoozed AND lost on that one…
    #25312
    James O’Brien
    There might still be one on eBay Britt if you haven’t figured anything out, It’s a 99 CKT mod. I think he wanted 300. Looked like it was in good shape. I have another, but it’s my championship setup from last year at SRK. So I would want a brick of gold for it 😉
    I’ll be up there Friday to run with you guys.
