Home Forums General Karting Discussion Is there any good way to protect a new suit??
This topic contains 3 replies, has 4 voices, and was last updated by  TJ Koyen 2 years, 8 months ago.
  • #48956
    James
    I’ve used Scotch Guard with no luck. Any suggestions ???
    #48957
    Get a brand new suit that you only wear for interviews, photo ops and podium.
    #48965
    Rich Hays
    A new suit for podiums etc. is a good idea and an option for some but not all. The best option that I have found is to use Molecule suit care and cleaning products. I have been using it for years on all white or light colored suits that get used nearly every weekend with a junior driver. Suits stay looking like new when washed after every outing.
    -rh
    #48990
    The Molecule stuff works wonders. They have a Suit Protector chemical that is a bit like Scotchguard. It resists water, dirt, oils, UV rays, grease, and helps guard the suit against staining.
