--> IKP Brake Pads… – ekartingnews
Home Forums Tech Talk IKP Brake Pads…
This topic contains 1 reply, has 2 voices, and was last updated by  Doug Ring 4 years, 10 months ago.
  • #3965
    Troy V Smith
    Ok, so I go to change out my brake pads yesterday and find that brand new IKP pads are significantly thinner (at least to me – 1.5mm) than new Freeline pads. With the new IKP’s installed, there is way too much gap between the pad and rotor (at least for me). I know I can shim them up, but guess I don’t understand why? Is there a reason they are thinner? How much “gap” do most people use between the pad and rotor?
    Thanks…
  • #4076
    Doug Ring
    Been a couple of years since I ran the Birel, but shimming is not at all unusual to close the gap. Birel dealers will have them, or you can make some yourself out of aluminum sheet. You may need to trim the retaining screw lengths, if the pads don’t have clearance holes bored through the friction material. IKP’s may be harder, hence less material on the pad?
