--> IAME Mini Swift will not take off…..any advice – eKartingNews
Home Forums TaG IAME Mini Swift will not take off…..any advice
This topic contains 4 replies, has 3 voices, and was last updated by  Chad Landers 1 year, 12 months ago.
  • #67281
    Aaron Abed
    I have a new Mini Swift (2 race weekends old) that runs fine once it’s up to speed but will not take off!  I literally need to push it to help go and get out of the hot grid and on the starts it’ll falls to dead last while EVERYONE passes.  Once up to speed (200-400 yards) it’ll be fine.   I’ve changed plugs, tested other carbs, rebuilt the carb, replaced the needle and seat, adjust pop off, replaced the coil, fuel line, pulse line, you name it we’ve done it.   We have a lot of tuning experience, so I’m not concerned that I’m getting the carbs setting wrong….besides I tried them all.  Its done this from day one!
    Anyone else experience this behavior from their mini swift?
    Aaron
    www.Excel-Racing.com
    info@Excel-Racing.com
  • #67284
    Michael Zahorski
    I don’t have any direct experience with the Mini Swift yet, but since you said it is a new motor, could it be the clutch?  Could the clutch be engaging too soon, before the motor hits the torque curve?  I had a similar issue with a Gazelle with a brand new clutch, that it was engaging too soon.  Just something to check if you haven’t already.
  • #67286
    Aaron Abed
    Now that’s one thing I/we didn’t check.   How did you correct on the Gazelle when you had the issue?
    Aaron
  • #67329
    Michael Zahorski
    I took it to our local kart shop, and he put it on a lathe and removed some of the material.  IAME clutches are known to engage a little early on the lower horsepower motors, and typically the clutches should be cut some prior to their first use.
    Once we got our clutch cut, the starts were much better and my daughter didn’t bog down and get passed so quickly when the green flag waved.
  • #67578
    Chad Landers
    Spray the clutch down with WD-40 and see if it takes off better.  Otherwise your ignition timing may be off.
