Home Forums General Karting Discussion Iame leopard bad crank and crank case question?
This topic contains 4 replies, has 4 voices, and was last updated by  baruch fishman 2 years, 11 months ago.
  • #55384
    baruch fishman
    Hi Guys,
    Take a look at these pics and explain if you can how can this happen?
    i realized that i bent the crank somehow someway so i decided to open the motor and see what is going on and i found this:
    i am just very curious on what could cause this to the crank case and crank itself .
    http://prntscr.com/8qy2vm
    http://prntscr.com/8qy36u
    http://prntscr.com/8qy3c2
  • #55403
    Greg Wright
    It doesn’t take a lot of twist in the crank assy for it to rub the cases.
    Greg Wright
    Rapid Racing Inc.
    Vintage B-Stock Pilot
  • #55486
    The shaft has to seat on the bearings. You might need some bearing shims. Crank should have at least .025″ wall clearance.
  • #55510
    FREDDY SANDOVAL
    Crank shaft may have become lose, or someone lost kart at a corner and spun backwards, and while going backwards kept pushing the throttle, instead of waiting till fully stopped.
    Or someone simply just accidentally dropped the engine, and landed on the shaft bending it, knocked it out of trueness or round.
  • #55696
    baruch fishman
    Thanks for the input !
