Home Forums General Karting Discussion Iame Leopard 07 Clutch engages at realow rpm's and overheat/smokes
This topic contains 7 replies, has 4 voices, and was last updated by  Walt Gifford 4 years, 3 months ago.
  • #24801
    Sebastian Sarmiento
    Hello Guys,
    I installed a new clutch and clutch’s drum a couple of weeks ago. Went to Infineon the weekend after that and drove it several sessions, everything was great.
    Today I fired it up and drove it around the block when I noticed that smoke and burning smell was coming out of the clutch. Took it apart and the bell was freaking hot! the shoes had some black build up on them (very thin). I would like to remark that the drum bell was running free, it wasn’t stuck or anything like it and I could easily spin the wheel.
    I carefully sanded the black coating on the pads, cleaned the bell and everything with carb cleaner, put it back together, check the wheel is running free (engine off) and fired it up again, even at very low Rpm’s the wheel spins (clutch is engaging), I could stop the wheel with my had, but the wheel is not supposed to spin at all at such low rpm’s. Took a short drive and again a chunk of smoke and smell.
    I apologize if I’m changing the names of some parts, I’m new to the whole karting sport and I’m still learning.
    Any ideas??
    I wish you twice as much of whatever you wish for me. : )
  • #24804
    Hate to tell you this, but you may have burnt up the clutch and drum by driving the kart around the block.  First, that is a dangerous thing to do unless you have a large parking lot in the middle of nowhere.  Second, by driving it around the block, the clutch may not have been fully engaged, causing the heat and smoke.  Is there any chance the grease from the bearing got into the clutch?
    On a stand, the wheels probably always turn, that’s normal.  Hold the brake pedle down and see if the engine stalls.  If it doesn’t stall, the clutch is not locked up.
  • #24805
    Sebastian Sarmiento
    Hey Tony!!
    Thanks for coming to the rescue ..again. lol. I would like to think it could be grease from the bearing, but I don’t think after 10 sessions  (where it never smoked) the grease would get in the clutch. I went to pick up the kart from Cambrian Gokarts (the owner brought it back for me from Infineon because I had my DD2 with me and in my truck I can only fit one). on my way home I stopped by me plumbing supply house (there’s a 200 by 60 yards parking lot there) One of the guys asked if I could show him how it works, so I did, but I didn’t drive it hard at all, then I saw the smoke.
    Thanks for your help!
  • #24815
    Isn’t Infineon a road course? By chance, was the kart still geared for long track? The gearing might have prevented the clutch from locking up because there wasn’t enough speed.
  • #24831
    If you had a tall gear and drove it easy the clutch was slipping allot. You cooked it. btw parking lot is recipe for flat tire.
  • #24837
    Matt Dixon
    Infineon, now Race Sonoma operates SimRaceway which is a world class kart track.
    They will be hosting rds 5&6 of Challenge of the Americas this weekend
    94y
  • #25025
    Sebastian Sarmiento
    Well guys,
    Tony and everybody else who said I cooked the clutch, are right. I guess I’m learning the hard way.
    I’ve already ordered a new drum, clutch and bearing, no more parking lots/showing.
    It sucks that this clutch/drum/bearing only had 1 hour on it.
    I asked one of the mechs at my local shop, he said the drum has to be replaced as well to make sure it doesn’t ruin the new clutch. Make sense to you?. Sometimes when you are new to any stuff you are never too sure if it’s BS to sell you more or a true fact.
    Thanks to all of you for your help!
  • #25030
    The clutch chain and sprockets are something that has to be kept pretty fresh so buying small parts of the drive train is like buying one new tire at a time for your car, the others will wear it out faster. Get everything new and take care of it the best you can will save money in the long run. The clutch should only get burned once per track session coming off the grid so nail it and it will lock up quick then keep speed up above clutch stall while on the track.
