--> Hubs on front spindles – eKartingNews
Home Forums Chassis & Handling Hubs on front spindles
This topic contains 2 replies, has 3 voices, and was last updated by  PJ Lyda 3 years, 10 months ago.
  • #30856
    brian downing
    I’ve noticed a few racers using hubs on their front spindles.
    What’s the advantage and when is it worth one’s extra time & expense?
    I’m running  a 2013 Margay Brava, Yamaha KT100 Y-Pipe.
  • #30866
    William Martin
    When you want a slightly stiffer front end…or just want to use hub-mount wheels you might have lying about.
    bill
  • #31452
    PJ Lyda
    As bill said the hubs tend to add a stiffer front end. But now most of the newer chassis run 25 mm spindles. Which they don’t make a direct spindle mount front wheel for which makes the you have to run the front hubs.
