Home Forums 2-Cycle Racing HPV/KPV rebuild info
This topic contains 6 replies, has 4 voices, and was last updated by  Walt Gifford 3 years, 5 months ago.
  • #40669
    Chris Towers
    Does anyone know where I can find information on building these motors? The manual I’ve found online (It’s the one for the HPV 100) doesn’t provide much info at all. I’ve seen that there is a book on building KT-100s and imagine some of the procedure carries over, but still leaves me sorely lacking on info directly pertaining to the HPV/KPV series of engines.
  • #40697
    I’ll tell you this, you can’t do it with just hand tools and the tools you need are a big investment. Do you want to get into the engine building business? The KT100 book is a good place to start for some general knowledge but, there are allot of details you learn from being brought up in the mechanic/machinist trades that are hard to learn from books or the internet.
  • #40863
    Glenn L Riggs
    Hey Walt have a question and thought you would be the guy to ask. How much wear on the crank main  bearing is allowed before performance start to degrade? Replace at .001 ? Whats your findings? I am sure you would know. Thanks
  • #41005
    John Mulvihill
    Hi Glenn,
    Not Walt, but here is my opine.
    I usually tear things apart at 6 hours (road racing).   If I find that the ball bearings are no longer mirror shiny, I replace (usually).   I also go 12 hours on the crank pin roller bearing unless it looks funky or the rod looks like it has run hot.
    John
  • #41238
    Are you talking about wear between the crank and the ID of the main bearing? I use to worry about that until I saw how they clearance the shaft on 125 shifter engines to loosen it up.
  • #41311
    Glenn L Riggs
    As a matter a fact I am talking about a tm special balanced crank 125 icc engine. when you make the wheels and shafts straight dead on the bearing on the pto is worn to a little over .001 on the journal. Engine has seemed to be a little unhappy pulling much over 13800 my other tms pull 14400 and was just wondering if the crank could be the reason. I remember somewhat the same happening back in the day with kt100. When we ran pipe and twisted the heck out of them, cranks didnt last long.  Thanks for looking Glenn
  • #41349
    A customer had 2 Comer ICA reed engines, one built in Texas turned 500 rpm higher than the one I built but mine got lower lap times. At some point it’s hard to quantify these things.
