--> HPV/KPV maintenance – ekartingnews
Home Forums 2-Cycle Racing HPV/KPV maintenance
This topic contains 3 replies, has 3 voices, and was last updated by  Finch Guenther 3 years, 4 months ago.
  • #40320
    Paul Hir
    I recently purchased a KPV/HPV, just curious what type of maintenance people do prior to the season and where you purchase parts?
  • #40324
    Stu Hayner
    Paul,
    You’ve just bought one of the easiest and lowest maintenance cost engines in karting.
    If the engine is sound now – it should be good all year w/o much, if any maintenance.
    If you don’t know how many hours on it – have an engine builder look at it.
    If you’re going to leave it sit over the winter and you can’t bring it inside, put a little Marvel Mystery oil thru the carb as it’s running – shut off – then put a teaspoon of MMO in the spark plug hole. Run the cylinder up and down a few strokes – then bag it in plastic. Moisture will hurt any engine if it’s not well lubed.
    If you need ANYTHING for the engine, give me a shout. I have bins of new and good used parts for the HPV. That engine is 95% of what we run out here in the F100 series.
    MDG Karting
    714 928-5278 shop
    714 305-6123 my cell.
    Stu
  • #40338
    Paul Hir
    Stu,
    I plan on doing a gasket change on the Carb, would you suggest changing the gaskets on the engine? It has been sitting for a while but is suppose to be newly rebuilt/blueprinted.
  • #40342
    Finch Guenther
    I personally would have my builder take a look at it before running the engine. At the very least I would pull the head and check the condition of the cylinder.
