Home Forums Tech Talk How to remove Clutch on a Yamaha KT 100
This topic contains 2 replies, has 3 voices, and was last updated by  Walt Gifford 1 year, 7 months ago.
  • #70774
    Anonymous
    Hi There,
    Just new in the sport…need help on removing the clutch on a Yamaha KT 100 I’ve been reading you guys forum and doing so… I’m learning  a lot.   I couldn’t find any topic regarding clutch removal here, You Tube, Racing the Yamaha KT 100’s book.  Does anyone have a spare Clutch puller for sale ?  Got an advice on the kind of clutch to get dry or wet and number of disk…with regards to my weight 185lbs. Wet clutch and 3 disk  I was told and also I read from you guys.  3 disk is best…does not put too much strain on the KT 100 engine.   Where can I get a 3 disk wet clutch ? I can only pay via Paypal  I haven’t looked in the classified ads. BTW I haven’t been in a Kart in almost 20 years…planning to join the F100 series and I hear that 360lbs limit in the senior class. Would this clutch be allowed ? Also the engine has a 3 hole can.  There’s a lot to read  I know and any help from you guys would highly be appreciated.
    Thanks, John
  • #70781
    Stu Hayner
    Hi John,
    Bring it down (orange) and I’ll get your old clutch off. I will check in the morning to see what KT clutches I have available. No matter what, I can get you up and running.
    Give me a call or text me at 714 305-6123.
    Stu
    MDG KARTING
    1657 N Glassell St
    Orange, Ca 92867
    714 928-5278 shop.
  • #71147
    You need to get the clutch puller and holding wrench that was made for your clutch. After that it’s pretty easy.
