Home Forums General Karting Discussion How to get chassis set up info?
This topic contains 5 replies, has 3 voices, and was last updated by  John Savage 5 years, 3 months ago.
  • #12135
    Rod Hawkins
    I run a Birel R31, but when that is sidelined, I have a Margay Brava 1.4 chassis that I just started running a HPV/KPV3 class. I am running 360 lbs wt limit (I am 180 lb). No one in my area seems to carry Margay so I am having a hard time finding out how to set up my chassis. Just looking for a good starting point.
    Front and rear track-width?
    Front torsion bar? What setting?
    Run my rear torsion bar or tube or go without?
    Run left inner frame bar or not?
    Run my 3rd bearing or let it float?
    next race is at super slick Calspeed at Fontana. Running YLC tires and 40mm rear axle.
    Thank you
  • #12163
    John Savage
    Try this:
    http://eknclassic.com/viewtopic.php?t=16096&postdays=0&postorder=asc&highlight=Brava+setup&start=15
    If you want more just search the Classic Forum, its a fabulous resource
    Jetting and Kart Set-up Software
    http://www.rotaxjetting.com
  • #12164
    Rod Hawkins
    John. Thanks for the link.
    Little more info
    Front track is 46″
    Rear track is 54″
  • #12208
    James McMahon
    Rod have you called Margay? I’m sure they would be happy to give you some pointers over the phone too.
  • #12448
    Rod Hawkins
    thanks for all the replies guys.  I sent Margay an email and they sent me back a detailed email on how to set it up.  I was also put in contact (by someone on this board) with someone who lives in my area and has had a lot of success running a Margay and knows how to get it dialed in.
  • #12450
    John Savage
    <div class=”d4p-bbp-quote-title”>Rod Hawkins wrote:</div>
    Great result – the power of ekartingnews in action!
