Home Forums Autocross / Solo 2 How big is a kid kart?
This topic contains 2 replies, has 2 voices, and was last updated by  Scott Boito 3 years, 1 month ago.
  • #49822
    Bill Schmidt
    I know they are smaller than our shifter karts, but can they be hauled in the back of a Subaru Forester, with the back seat folded down? Looking to buy a kid kart for my Grandson.
  • #49853
    Scott Boito
    Depends on what size.  If you’re talking about the “baby” kart, for 5-8 yr olds, then absolutely it will fit.  The baby karts are the smallest and usually only run with the Comer C50/51 or the newer Honda GX50 motor.  There is no minimum weight and the wheelbase is only 30-35″ and total length is around 50″ with nose attached.  Maximum width is 42″ and usually narrower than that.
    Cadet karts are longer and a bit wider.
  • #49856
    Scott Boito
    Bill, if you haven’t visited previously, check out http://www.kidkarters.com/get_started.htm for some pretty good info.  You’ll already know a lot of it, but there are some good reminders in there.
