Home Forums Tech Talk Horstman HDC-5B vs HDC-5CX
This topic contains 4 replies, has 4 voices, and was last updated by  PJ Lyda 3 years, 8 months ago.
  • #29467
    Brad Alan
    I’m in need of a new clutch for a yamaha Sr. class (running the Y-Pipe).  Does anyone have any insight as to which clutch would be at an advantage for this class?
    The HDC-5B is Horstman’s dry 2 disk clutch which is commonly used in the Sr. Can class.
    The HDC-5CX is Horstman’s relatively new 3 disk clutch.
    I know of some guys running both in the Sr. Class, but I don’t know anyone that has done any testing.
    Any insight would be great.
    Daniel White
    I used the 2-disk Horstman for the can class and, later, for the Y-Pipe. I was completely inept when it came to adjustments–all I did was service it between track days. Needless to say, it eventually became unpredictable to feel when the clutch would engage, and in my ignorance I thought it was the fault of the clutch, that it worked for the can but was less effective for the Pipe.
    One day the drum broke, and to me this confirmed that the Y-pipe was just too much for the 2-disk to handle (I was wrong). So I borrowed a fellow racer’s 3-disk dry clutch (a Patriot). It worked much better than my 2-disk and was more robust, so I arranged a trade (after replacing the broken drum with a new one). I’ve been satisfied since.
    But I’ve since been told that the 2-disk is just fine for the Y-pipe. In fact, I’m the only one at my club who uses a 3-disk.
    Daniel White
    Forgot to add: at a certain weight having a 3-disk becomes the preferred choice, though I’m not sure what the weight is.
    I would run the 3 disk, who needs clutch maint hassles.
    PJ Lyda
    We have ran both the 2 disc and 3 disc in the can but have found that the 2 disc works better on larger tracks like new castle and the two are pretty even on the short tracks just due to the extra rotational mass on the 3 disc. On the Y pipe we have both as well and found that they are about even on track each have their own benefits but the 2 disc has less rotational mass which is the main reason most people run 2 disc in Yamaha. Personally we have switched to tomar 3 disc which has been a very good clutch on the     Y-pipe and the can.
